Question on converting 5 lug for ABS.
mrgrape
Car: s14
Okay I have an s14 4lug and i want to convert to 5lug for more wheel option.anyways i already know for the front i need s14 OEM or aftermarketand for the rear i can use s14 OEM, aftermarket, or z32 NA.
I was told I need s14 hubs with ABS rings on them.....if so where do i get that....and do i need it for both front and rear?thanks
mrgrape
Car: s14
bump
mrgrape
Car: s14
BUMP MUTHAf***ASSSSS
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Yo, you havent learned how to search yet. This has most certainly been covered many of times. I thought they would have banned you by now. Use the search button. You have failed again.
mrgrape
Car: s14
i did search fool.]nothing on ABS.only what u can use, such as 5 lug rotos,
please dont talk s*** when u dont even know..
SpeedmanRC
Car: 2000 Legacy 1997 240sx
The front has the tone ring around the hub, so it sounds like change the hub for one with a tone ring to a five lug and will work.
the back has the sensor and tone ring around the input side of the rear diff, not change is needed back there. Just change the hubs to five lug and be done.
the FSM will help, tone ring is equal to sensor rotor.
LoserCard
Car: Forest Green 1993 240SX SE Fastback
Like SpeedmanRC said above, all you need is the front ABS hubs to retain ABS. That being said...
http://www.lmgtfy.com/?q=96+ni...y&l=1
blacksrjdm
mrgrape wrote:i did search fool.]nothing on ABS.only what u can use, such as 5 lug rotos,
I know very well, my s13 has been 5 lug for 4 years. If you want to retain ABS then you would obviously need ABS hubs. You are the fool and you fail.
