question on clutch lsd into a vlsd pumpkin
AN89HATCH
I am thinking of picking up a 180sx vlsd, and was wondering if i was to throw a clutch lsd into the 180sx vlsd pumkin will I still need another vlsd left side shaft, or will this be a direct bolt into a 180sx diff?
574-240sx
Car: Nissans, Toyotas, Subaru
If you were to buy an aftermarket clutch type LSD you should buy one that will bolt into a open diff. You would save money this way. You don't need a stock VLSD punkin and axels to get a clutch type to work unless it specifies.
Dattebayo
I just posted something about this like 4 hours ago or something. Z31 84-87 Turbo clutch type internals will swap in. I think you need the outputs from that pumpkin though...
AN89HATCH
hmm I cant find your post, do you know what will be needed to make it work in my open diff 240sx? will the stock 240sx axles bolt on to the z31 out put shafts? if not from what car axles will i need to use?
