Sway bar end links rubber seals pop. You should check them. Also those round rubber bushings get old and become flat or have crack. Replace them all at once while you are at it.574-240sx wrote:Throw in the new set of LCAs. Just pick up a set of sway bar end links if you are worried. If they are rusted and this old they are probably bad and worn out.
