Question on auto. Convention to stick shift ??
Luis300zx
Car: 1990 Nissan 300z32
Kind of confused... ¿?.. My ecu is for an automatic 1990 300zx na, and I swapping everything to a shift.. But I'm getting info like.."you can use the same computer for the manuel transmission even thow it's set up for an automatic".. "All you need is an upgrade" ... Wondering if this is true or not..... ???? What is the correct way to have my computer set up for a stick shift transmission?? :gotme
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
It's true. It's not as simple as dropping the trans and putting the new one up though. You'll need a bunch of different accessory parts, like the shifter bracket, clutch, pedals, cables, and more.
But yes, you can swap the trans and keep the Auto ECU and TCU.
Fearspect
Car: 1990 Nissan 300zx TT 2+2
There is a wiring harness you can get from wiring specialties that lets you hook a manual into an auto ecu
Luis300zx
I got everything to do it. Like the petals, wire harness, shift plate , braided clutch line, one pease drive shaft .. Etc... But just was questioning on the computer part. Thought I have to get a manual ecu for the swap .. Might just get an upgrade on my stick then .. Thanks
DSble315
Car: 1990 300zx na
Fearspect wrote:There is a wiring harness you can get from wiring specialties that lets you hook a manual into an auto ecu
so what happens if you don't get this harness? Sorry electrical things confuse me :frown:
Luis300zx
I beleave your Reverse light / back up - Neutral safety switch wount work .. And I'm getting a new one from concept Z .. Old one was eaten by Squirrels..
nissanfreak12
Car: 92 300zx 2+2 TT
You can use your auto harness, just have to wire it in to the correct wires. The manual harness you guys speak of will make it cleaner.
Also when doing the conversion, you will either need to rewire the starter relay or jumper the wires. I could never get jumper to work, so I just rewired with a different relay. Have not had an issue, I just don't have it wired through the alarm.
