question on active suspension.....any pros who know this please help
rasrx7
Car: 95 q45
91 President
94 Q45
03 Xterra
92 240sx hatch
93 240sx cionvertible
91 240 sx coupe
74 260z
73 240z
79 280zx
70 510 sedan
71 510 sedan
I need to know what the maximum travel for the active suspension system in the g50. According to some people i talked, the most movement is about 3 cm. Is that correct? When i was buying my q45, i test drove some active suspension models and i remember having alot more travel, at least inches of movements...not cm...can some one help me out. Trying to figure out the suspension on the president and if its only cm of movement, then not worth my time worrying about. Thanks for any help in advance.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Speak to Keith. http://www.q45asuspension.com
I am sure it is a least as much as the non-active, i.e. - 4 or 5 inches.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
rasrx7 wrote:I need to know what the maximum travel for the active suspension system in the g50. According to some people i talked, the most movement is about 3 cm. Is that correct? When i was buying my q45, i test drove some active suspension models and i remember having alot more travel, at least inches of movements...not cm...can some one help me out. Trying to figure out the suspension on the president and if its only cm of movement, then not worth my time worrying about. Thanks for any help in advance.
I posted it in your other thread.....!!!
elwesso wrote:The total stroke on the strut is 5.7". I would think that would mean you could lower or raise the car at least 2 inches from the normal height..
Q45tech
Just like almost all shocks have a 7" stroke the system movement probably exceeds +- 3.5".
The system holds the body level until 0.5 G is exceeded then the strings and away bars are allowed to compress/ expand as on a conventional suspension.
rasrx7
Car: 95 q45
91 President
94 Q45
03 Xterra
92 240sx hatch
91 240 sx coupe
74 260z
73 240z
79 280zx
70 510 sedan
71 510 sedan
opps..sorry..i forgot ...ive been getting alot of mixed reviews and been getting alot of answers that say its less... so im just trying to get more reviews and answers..sorry again..but i appreciate your help alot.
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
I can't give you a specific number for the travel on my Active... but, I can tell you it's definately inches not cm. I left my car running and jacked it up once (don't do that fellow active owners) and had the car up at least 3" and the wheels was still on the ground.
For whatever that is worth to you.
one ton garage
rasrx7 wrote:opps..sorry..i forgot ...ive been getting alot of mixed reviews and been getting alot of answers that say its less... so im just trying to get more reviews and answers..sorry again..but i appreciate your help alot.
That's because you're confusing suspension travel with adjustability. The struts themselves may have 5.7" or so of *travel*, but that doesn't mean you will be able to use a controller to slam the car itself down 5.7"... not even close actually, if at all.
elwesso
2007 BMW M Coupe
right..... you have to figure that the car sits somewhere in the middle, and that youd be able to go about 2-2.5in in either direction.
