Second Shadow »
https://forums.nicoclub.com/second-shadow-u4629.html
Sun Jun 28, 2009 10:12 am
The short explanation is I want to basically switch the AC condenser and the intercooler's places.
Still running the stock IC, and looking at some upgrade options. It seems to be that if I can put an IC about where the AC condenser is now, I can use a larger core and still keep the lag down due to shorter piping(they can go right through the core support and strait to the turbo and throttle body).
Now the IC is more important than AC, so what I've got planned for that is gonna happen no matter what. But what I'm curious about is if it's possible to put a more compact, but thicker, condenser where the stock IC is now?
It looks like an evaporator would fit there, have room for a fan, and it would prob have the right fittings, and there basically just heat exchangers anyway. a few fabbed lines to run there, and a few relocated smaller parts are no problem. I'd like to keep the AC if I can, but I need that condenser core out of the way.
Anyone have any thoughts on this?
