teammcw »
https://forums.nicoclub.com/teammcw-u95226.html
Fri Jun 27, 2008 10:34 am
Not at the car right now, but if I recall - when you search by name, it does exactly that... It looks in its database, and however that was organized, it will show up...
You have to click the Search by Dist button thing, instead of by name... I don't remember if you can make that default, but if no one else finds out, when I get back to the car I'll check.
Remember, for the most part, you can change some settings within the "Settings" menu, and also within the Main Nav menu... Just check through those. Or, you can try calling your local Nissan dealer to see if they have an answer.
