keelhaul wrote:from 2h to 4h u can shift "on the fly" while u are moving. my transfer case stick goes 2h-4h-N-4L. from 4H to 4L u must be stopped in neutral and I find it best to go from 4h to 4L in one quick motion skipping right past neutral. if it does go in neutral i shut off the engine to shift back into 4h or 4L to avoid grinding. the trick is to shift quickly
Ok so that Is my problem, I doesn't do it quick because I'm sceared to brake something!
Because I do put it in neutral, after the truck is completely stop and then I try to shift put I go from 4H to neutral, to 4Lo!
I'll try it quicker!!!
Thanx!
