squeefoo wrote:This site is sssoooooooo sssslllooowwwww. Is it because the security is ramped up after the invasion? Otherwise I'll assume it's on my end. THX BTW what the h*** is it about screwing with a bunch of guys that like old Nissan products?? I suppose it's the modern (web) equivalent of breaking some windows at the elementary school and running away. O tempore! O mores!
Try going to nyc.speakeasy.net and using their utility to measure your connection speed, if it's not what you think it should be try logging off, disconnecting your cable modem, unpluggong the power, wait 2 - 3 minutes then reconnect and you should try the speakeaasy measure again. If it's still slow contact your ISP??
