JDMracer16 »
https://forums.nicoclub.com/jdmracer16-u28895.html
Thu Aug 04, 2005 3:49 am
Im changing the plugs and wires tomarrow, and im swaping to a FMIC hopefully within a week. Now, the timing could be off a little. I dont know if this has anything to do with it but when ever i slightly get into boost (2800-3000rpm) the engine tends to hesitate or sputter as if the governor was kicking in and the engine was cutting off. Now, if im giving it full throttle then it doesnt do that, only when im driving it easy. Also, the car will cut off every once in a while when im coming to a stop if i dont down shift through most of the gears, but always cranks back up fine. If it is the timing, how would i go about checking and fixing it?
Thanx for all your help,Taylor
Modified by JDMracer16 at 2:28 PM 8/4/2005
