question need advice...
Roger_cha
Car: 91 nissan 240sx
my cousin just bought a 91 240sx with a ka24de and he wanted to put on some q45 370cc injectors and a n62 maf on a stock ka24de and he wanted to get this chip to tune with his setup. http://cgi.ebay.com/ebaymotors...ories he email them and they said that they could make a tune for it. but my concerns is that 370cc injectors and a n62 maf on a stock ka24de, wont that make it run rich or it depends on how they tune it. basically what he has in his 240 is intake, catback, lightweight flywheel, XTD 6 puck clutch kit and walbro 255 fuel pump, can anyone give some advice and is it a good thing to run it.
mutz22
Car: 95 240sx, 96 A4 Quatro2.8 , 1991 240sx hatch
I am not sure if the Q45 injectors are high or low impedence, almost positive there high so should work. It is not necessary nor practical stock injectors and a stock MAF will be just fine if he really wants to get a tune for whats done to the car. As for it making much of difference it wont. If he wants to build an NA KA its not worth it at all.
Roger_cha
well he just wanted to see what different it makes if he throws on some 370cc injectors and a n62 maf. right now he has bolts on with 255 fuel pump and XTD 6 puck clutch kit.
mutz22
Without a tune it will run like crap. With a tune it will run the same as tunning it with a factory MAF a stock injectors, just might have a bit worse of an idle due to the size of that MAF.
Roger_cha
well i guess its a bad idea for him to put on the n62 maf and 370cc injectors then. ill tell him not to do it until he goes turbo then.
