JayArr »
https://forums.nicoclub.com/jayarr-u17400.html
Sat Jun 26, 2010 8:52 am
Picking it up and carrying it around the shop is easy. Taking it off the car without a transmission jack of some kind won't be. With the car on either ramps or jackstands and you underneath "catching it" it's going to seem a lot heavier.
When it's time to re-install you're going to need to get it off the shop floor, up into the tunnel, aligned and at the right angle. It can be done with a regular floor jack and maybe some bits of wood for leverage and a friend helping but I would bet it will take hours longer that way and if you get it partially on at the wrong angle and try to wiggle it you risk bending your jack shaft and ruing it.
Spending some money ($50) on a transmission jack with the adjustable angle thing will save you hours and maybe a crushed finger or knuckle.
I've done it both ways, I prefer to have the right tool.
