QUESTION FOR TUNING PROS FOR SR20DET
A place to discuss the systems and methods of tuning Nissan engines.
HaWaIiAn821
Car: 02 F550 Ford Dually,01 Chromed Yamaha R6,95 240sx
i got a redtop s13 sr20 swap.. my buddy has a tuned ECU which mine is stock,we put it in my car,(which has a stock ECU),cranked it over,started right up but started running rough so we shut it off,we put back the stock ECU back in and it does the same thing,i checked everything,injectors,air intake,but on my SAFC, the air isnt reading which is causing my car to run really rough and rich.... we disconnected the battery to see if maybe the stock ECU would reset or and anything,NOTHING!!! im getting power everywhere except to the AIR on my SAFC?? any suggestions? ideas? thanx for the help
Axel Grungy
Car: 2001 G20 5spd
moved to sr forum
SpeedRacer1
Car: 1990 240SX, G35
Maybe you undid the connectors for the SAFC.
xsublimefrekx
Car: 1991 s13. SR20det, 1998 s14
you sure the MAF is hooked up right to the SAFC
panapower
Car: 1993 sentra, 1998 Acura gsr, 1965 mustang
xsublimefrekx wrote:you sure the MAF is hooked up right to the SAFC
that's the first place I would start. then start checking for continuity on all your connections back since you were fooling with the ecu and wiring harness.
da40
Car: 1995 SE 240sx
sounds like u just got a faulty connection down by the ecu harness(process of elimnation)
S13FASTBACKSR
Car: '92 Fastback SR powered
ya im with da40 ..make sure you bolted down the connector to your ecu all the way.
nzmoman
Car: 240sx 2 of em' and always lookin for more
HaWaIiAn821 wrote:i got a redtop s13 sr20 swap.. my buddy has a tuned ECU which mine is stock,we put it in my car,(which has a stock ECU),cranked it over,started right up but started running rough so we shut it off,we put back the stock ECU back in and it does the same thing,i checked everything,injectors,air intake,but on my SAFC, the air isnt reading which is causing my car to run really rough and rich.... we disconnected the battery to see if maybe the stock ECU would reset or and anything,NOTHING!!! im getting power everywhere except to the AIR on my SAFC?? any suggestions? ideas? thanx for the help
why did you put a tuned ecu on a stock motor? If it wasnt broke what were you doing?
Return to “Engine Tuning”
