mechanicalmoron »
https://forums.nicoclub.com/mechanicalmoron-u183526.html
Thu Jan 31, 2013 10:19 am
My best answer is, determine which one you can retrofit a cup holder into more easily, and get that one.
Seriously.
Suspensions are pretty similar, s14 subframes can be put in s13's, I think, though they have slightly different larger parts, to keep the geometry right. They share some other parts. s14 is newer, and will have less wear on rubber parts and stuff. s13 usually looks way cooler, s14 is generally bigger and roomier, and has a longer wheelbase and wider stance. It also looks like something toyota would make, unless it's kouki. s13 is OBD1 (so are some s14), and requires more work to put an OBDII engine or other junk in, but also has one cat and probably generally less emissions rules. There's no cat check o2 senser, and so there's nothing to check that it's not gutted or removed, as long as everything looks right. In other words, less emissions checks means less fake emissions gear you need. But s13 does have a pair valve, that gets in the way and can jam open, requiring removal or cleaning.
I think s13 is drifted because it's cheaper because of it's age. Of course, there's a point where that will make it more expensive, especially after enough are drifted into solid objects. Most aftermarket stuff either works on both, or when you buy it you choose which version you want, s13 or s14.
I think that's it?
mechanicalmoron on Thu Jan 31, 2013 10:24 am, edited 1 time in total.
