Tampa G35 Sedan 6MT wrote:When you replace a transmission do you replace the clutch?
Not unless it is required. It is very hard to get clutch covered under warranty. Most of the time they are overheated and cannot be resurfaced.
Tampa G35 Sedan 6MT wrote:Also my car lately has been making a noise like when I go over speed bumps... kinda sounds like the front tires are rubbing something... I have checked and nothing is rubbing or in the way. Do you know what that could be?
Another one is since the rubbing the car also creeks when backing out of a drive way or going over irregular bumps or pavement where the car has to flex.
This sounds like compression rods to me.
Tampa G35 Sedan 6MT wrote:I hear the creaking in the sunroof! Is that normal?
Lift the sunroof to the tilt position and using glass cleaner and clean the window seal. Then open the window fully and clean the crap off the corresponding body seal.
Tampa G35 Sedan 6MT wrote: Lately when the car is idling (I know the 6MT' make some noise when the clutch isn't pressed in) but it can be really loud at some points.. Where when you are away from the car you hear the chatter over the exhaust note
Last one... When I turn the car on in the morning and the car is cool I get this loud chatter or some type of noise coming from the clutch/transmission and I feel some type of shutter or vibrations into the clutch peddle. This then goes away when the car comes down on the idle. This doesn't take place when the car is warm.
It sounds like you have a failed input bearing in the trans. I cannot say that it is completely that and not just a release bearing. If the noise is similar to that of a roller bearing (cannot think of a way to describe it better) I would suspect the input bearing and that should warrant transmission replacement.
