J2/J3/E4/E5 uses pin number 111
Type X J4/J5 ECU uses pin number 102.
I just went out to the garage and confirmed that the connector for the boost solenoid is indeed the plug with the orange/black wire and brown wire.
The wires running from the solenoid (black and white) connect like this:
Orange/Brown -> BlackBrown -> White
Extend the harness plug about 3 feet (I had my boost solenoid connected to the mounting plate and onto the driver's side strut tower), plug into boost solenoid and you should be good to go.
Vacuum diagram:
Solenoid on mounting plate:
Solenoid mounted to vehicle:
For more information refer to responses in this post:
zerothread?id=340154
