question for rob or apple or anyone really?
Beak
Car: 08 Coupe VQ
yo i wanted to ask one of yaw since you are audio g's. i got a deal on this amp. http://www.alpine-usa.com/US-e...-M500. its the alpine MRP-M500. what sub would you suggest this amp could push nicely? i was thinkning alpine type r 10'' but im not sure if this amp can handle it. one more thing if the sub is 2 ohms it pushes 500 w and a 4 ohm would push only 350w? is that right? so if you had this amp which sub would you pair it with? thanks
Infantry1327
Car: 08' Nissan Altima Coupe SE
It should push the Alpine SWR 1022D. You can bridge it down to 2 ohms. Whats your budget on the sub? What kind of music do you listen to? What kind of head unit are you using?
AppleBonker
Beak wrote:i was thinkning alpine type r 10'' but im not sure if this amp can handle it. one more thing if the sub is 2 ohms it pushes 500 w and a 4 ohm would push only 350w? is that right? so if you had this amp which sub would you pair it with? thanks
The type R would work fine. You can use the R and take advantage of all 500 watts the amp can produce.
Infantry1327 wrote:It should push the Alpine SWR 1022D. You can bridge it down to 2 ohms. Whats your budget on the sub? What kind of music do you listen to? What kind of head unit are you using?
However, you want to go with the 1042D which is a dual 4 ohm that can be wired to a final 2-ohm load. The dual 2 ohm will get you either 1-ohm (not stable) or 4-ohms (less power).
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
Beak
Car: 08 Coupe VQ
im using the bose unit. i listen to hip hop, house and drum and bass mostly.
big thanks guys
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
I can't wait to start working my audio
Broadfield
Car: 1992 240sx
Double
......Or maybe a JL 10W6v2-D4, but it will run you a little more money.
Beak
Car: 08 Coupe VQ
cheers
