96Qowner wrote:Lower tax rates do not typically produce lower tax revenues. Republicans argue for two things: Lower tax rates and smaller government. The private sector makes the money, not the government. When you leave money in the private sector, it earns money and is taxed, producing larger tax revenues.
96Qowner wrote:By reducing rates, you help starve the wasteful government and you produce more economic activity in the private sector.
This is, by and large, nonsense.
You can't "starve the government" by reducing tax cuts unless you institute something like PAYGO, a measure that the GOP has repeatedly shot down. The government has and will continue to borrow whatever the shortfall is between spending and tax revenues.
When you're running a deficit, any tax cut not matched by an IMMEDIATE spending decrease is just a dollar that then must be borrowed.
Stimulative tax cuts also only work in very limited circumstances, and they face a very real wall of diminishing returns. In a recessionary environment, if you cut taxes $1 to the middle class, there is a very high likelihood that those people will then go out and spend almost the whole dollar. Rich people will go out and probably invest almost the whole dollar (some percentage of it overseas, likely).
As you increase the amount of the cut, however, people will begin to save more. If you cut another dollar, they might only spend/invest half of it, and then save half of it. The saved half has no impact on tax revenues. This same phenomenon is present with the wealthy, as a higher and higher percentage of each incremental dollar will go overseas rather than here, because putting more money in the system doesn't increase the number of domestic investment opportunities and thus the dollars will just get sent elsewhere after awhile (see: 2002-2008).
Thus, in the grand scheme of things, a tax cut DOES decrease tax revenue. You can't decrease the deficit unless you decrease spending contemporaneously (and by a greater amount) than you are cutting taxes.
You CAN stimulate an economy in time of crisis with a tax cut, although only to a point (i.e. the first few "dollars"). Interest rate manipulation is much more efficient after that point, as the wealthy can't save an interest rate, they have to use it to invest, or lose the opportunity.
If you're serious about reducing the deficit, you should cut spending AND raise taxes. It's not what people want to hear, but math is math. All this "trickle down" horseshxt is a bunch of 1+1=4 nonsense that the GOP has successfully sold it's constituency because people want to believe it. Not true, not so. No pain, no gain.
