nismo1219 »
https://forums.nicoclub.com/nismo1219-u41473.html
Sun Nov 30, 2008 6:39 pm
dude, i bought mine off ebay about 3 yrs ago now...i paid about $450 shipped and it still looks just as good today as it did then. installation is basically bolt-on and you can do in your drive way with a friend if you want so they can help you remove the old hood and put the new one on. depending on the hood you actually get, you may need to play around with the hood alignment brackets on either side of your engine bay, under the tops of the fenders. I had to loosen my fenders in order to get to mine more easily. i also needed to sand down a small portion of the fiberglass shell that measured about 2" x 2" because of my front strut bar but other than that, you should be set to go!! good luck, and i expect to see some pics!!
Modified by nismo1219 at 10:50 PM 11/30/2008
