Question for people who did needle swaps
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
Mine dont work now. I just did a straight swap I believe I pushed them in to far. Anyone else have this problem??
locoluna825
Car: 90 240sx coupe
sweet awesome mod, no dude they look great
samxini
Car: '95 240sx w/Kouki conversion
I've heard that when removing the old ones if you pull to hard, that can cause them to break.Might need a new cluster, I'm not sure though.
Xdisaster240sX
What could I brake. I pulled the pin with the needles still on them. I also put them back in the same place. Man...this sucks.
locoluna825
Car: 90 240sx coupe
OH LOL they don't work? wow that sucks umm i dont know you sure you plugged everything in?
Xdisaster240sX
well...the rpms work. I think their getting stuck on the screws
nitsujvg
Car: 89' 240sx fastback
when someone does this 100% correctly, I'd love to see a write-up for it.
i've searched around and read through a few threads, but haven't yet found a write up.
Ramonesfreak2010
Car: 1993 240sx Hatch
94_240sx didn't recommend doing this mod. If its broken, buy mine. Check link. I'm in MD too. lol
nitsujvg
Ramonesfreak2010 wrote:94_240sx didn't recommend doing this mod.
yeah i heard. i think im just going to do the paint-pen technique but i haven't seen any pics of it.
94_240sx
Car: 94_240SX
They look good. Color on needles looks better than the other guy's. If I were you, I would get 2-3 extra clusters and swap the needles on speedometer until it works. SOHC clusters are easier to find than DOHC's.
rico05
Car: 1992 RMS13 w/ CA18DET
I swapped to blue LEDS and used a red sharpie on my needles yesterday and you can't see the light through them now. Seems like we are stuck with crap colors.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
i did the needle swap a few weeks back ago. mine turned out ok. but i didn't pull the needles straight out. i twisted them off and put them back on the same way.
S13Teddy
Car: R32 Skyline, S13
I really want to do this to both my cars. But if they break really easily, that kind of sucks.
Second Shadow
Car: 93' 240sx, s13 blacktop sr20det
if you pulled the pins out with the needles than yes you can put them back in too far. But you need to know how its not working, is the needle simply not moving or is it binding on something?
you can check this by pulling the clear cover off, getting up some speed and then very gently pull on the speedo needle. don't pull it out just away from its seated position so it can move freely. if it's just binding it will move to the correct speed for a moment before resting back on whatever is binding it.
if it's just binding on something you can pull the pin out a little, or completely and then put it back in but not as far this time. if the gauge is simply not functional then you need to replace the speedo or get a new cluster.
also, did you just change the needle or is ther more too this?(ie: LEDS or something under the needle hub).
mRodiek
Car: Stock Hatch
I wouldn't call this a "mod" but whatever, just grab a sharpie in the color of your choice and put one thin layer in the needle without removing it and wallah! your riding in style. Thenyou don't have to worry about breaking anything the way I did too lol
kwizle
Car: 1993 - 240sx SE hatch
1993 - 240sx SE hatch 5 speed
I replaced the old bulbs on my 1993 hatch and not the speedo doesn't work, it lights up and all, but it just sits at 0 mph. And also my RPM needle is kinda jumpy
