93RPS13 wrote:How much does it cost for the driveshaft to do the Rb25DET swap in S13? Thanks night
roundrocktom wrote:Maybe it is just me.... but StephNic has a good point... it is not that expensive.
What you need to do:MEASURE the END of the Transmission to the diff flange with the stock set up. Write this down.
Once the RB engine is installed, and in position desired, repeat the measurement from the end of the transmission to the diff flange.
Make a sketch of both measurements with OLD AND NEW label. Make a note "diff does not move, IRS" on the paper. Take the sketch, with the original driveline, and new transmission flange to a driveline shop. Most of the shops around here will charge about $125 to retube and ballance to front tube.
Not sure where to go... ask around about friends who have 4x4 vehicles and swap motors. Driveline modification is very common (for slow moving off road vehicles I've done my own driveline from DOM tubing.... vibration is not an issue with a 30 mph speed.... for the 240SX let a driveline shop do it and ballance the assembly.
Tom
chachi longshot wrote:I think with the RB25 swap though you need to shorten your driveshaft. Is that $125 amount including having the drive shaft shortend? Can you even do that? But if you go with a new custom driveshaft it should be much stronger than the stock one.
NightXCZ77 wrote:A driveline shop would have to cut and weld or take the tip and replace it. I had it done with my first driveshaft (half RB, half KA). The 300ZX yolk is what you use if doing the yolk conversion which isn't recommended. It's a short fix, but I recommend getting a custom one built for the swap...it will be stronger and last longer. It's really your choice here.
Night
StephNic wrote:why dont you recommend it? peoples stock ones have lasted to over 400hp. whats wrong with it? most driveshafts dont start showing problems to 600hp atleast.
Night
Bobby_Wu wrote:I'm leaning more and more towards getting a RB25 everyday...Night::..: what's the estimated price on custom building a drive shaft???
Bryson wrote:and Stephnic... I think you should ask Night before you start saying what he DOESN'T do... he is using a single tube driveshaft that a shop makes for him... so... me thinks your wrong...
NightXCZ77 wrote:Actually, I have CUSTOM driveshafts built by a professional driveshaft shop. They actually make a 3" double thick walled, lightened single tube driveshaft.
The reasons for getting a custom one are as follows:
1) They have replaceable U-Joints 2) They are stronger and last longer than stock3) They have less hp loss through your drivetrain because there is no intermediate carrier bearing.
I orignally had a modified stock driveshaft of which I used for about 4 days while waiting for my custom one to be finished. All shops near me wanted atleast $450 to get them made, this guy only charged me $392.30 I say I don't make anything on the shafts because I have to drive 45 minutes over and back about 35 miles each way which takes up quite a bit of my time and uses about 4 gallons of gas in my 90 SOHC 240....so about $7 in gas.
Night
FAST-DATSUN wrote:StephNic
I'm not sure where you get you driveshafts made, your price are low. here in SOCAL you can not get a QUALIY shaft for those prices even at wholesale. And a certified NHRA shaft would not even be close....
Cattalbus wrote:thats damn cheap for what they offer, I book marked the site.
