Question for hardbody gurus!
ashley_marie
Car: 2004 Xterra and B13 Sentra Se-r
Tonight on our way home we were driving the truck. Everything was fine and the truck was perfect as usual. I shifted from 1st-2nd-3rd then it would not go into any other gear. I could not get it out of 3rd at all. Luckily I got it home. When we got to the house I took the shifter assemble apart hoping it was maybe just the shifter or something. I have clutch pressure and I can engage and disengage the clutch just fine so I am thinking it is something in the rear of the trans causing it to do that. I tried putting a large extension in the shift fork and trying to take it out of gear but it was a no go. The truck is a 1997 2WD 4cyl(ka24e) with a five speed trans. I have never had any issues with this truck so I am kinda surprised. It has not once popped out of gear or made one grinding noise. Any help would be awesome. Thanks.
JC87HB
Car: 1987 Nissan D21 HB
Check your master and slave cylinders... Check slave cylinder first... like a 10-15$ part from an auto parts store. my clutch pedal had pressure, but the gaskets and seals inside the slave cylinder where gone!
ashley_marie
Did your truck get stuck in 3rd gear? I can not even get it out. If it was that I would at least be able to take it out of gear.
Saudade
Try rolling it backwards with the clutch depressed (engine off) and see if you can shift it.
Did it go into gear OK when this happened or did you force it a bit? Did you miss the shift?
JC87HB
i didnt get stuck... but it was almost near impossible to get it out of any gear once it was in a gear
ashley_marie
Saudade wrote:Try rolling it backwards with the clutch depressed (engine off) and see if you can shift it.
It went in smooth as butter! Than after that I could not get it out of gear. I did not miss the shift either. Thanks for the help guys, the more the better.
JC87HB
Now i do remember a video on youtube about this guy running the crap out of his beater HB and his transmission got stuck in third also... he said in his comments he had to retire the transmission and get another... ill keep searching for any trouble shooting tips in my Haynes manual.
ashley_marie
Thanks man!
Q451990
Definitely check the clutch master/slave cylinder. If the slave isn't pushing the arm in on the transmission, you know there's a problem there...
Heath
JC87HB
Also check to see if the arm is jammed... still should come out of gear though when its not cranked... something has got to be seized...!
ashley_marie
Q451990 wrote:Definitely check the clutch master/slave cylinder. If the slave isn't pushing the arm in on the transmission, you know there's a problem there...
Heath
The clutch has pressure....Its the trans, problem figured out. Thanks guys.
