Question for DOUBLEDIN aftermarket stereo owners....
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
br4dysays
Car: 06 Nissan Altima SE-R
do i need a mounting kit or will this headunit fit?
http://www.crutchfield.com/App...specs
crutchfield doesnt show one with the install gear they give you, so i assumed no?
just wanted to make sure i had all the necessary things to install.
CodeRed
Car: 2008 Nissan Versa S MT
For double din stereos you can use the stock mounting brackets.
DejaWiz
Car: 05 Honda Odyssey EX-L
See sig for details.
Save yourself $80 and get it from SE. They give you all the install hardware just like Crutchfield does.
http://www.sonicelectronix.com....html
Visaversa
Car: 2008 Nissan Versa S Sedan
If you would have clicked on "installation details" it would have told you to use your factory brackets, nothing else needed. This is, of course if you entered your vehicle year, make and model.
br4dysays
DejaWiz wrote:Save yourself $80 and get it from SE. They give you all the install hardware just like Crutchfield does.
actually i ordered it from amazon for about 372$ shipped, then ordered the other needs separately, so cost around 400$ total.
thanks for the info, i assumed i didnt need anything but wanted to double check with the people who know best
DejaWiz
Very nice deal on that! Let us know what you think when it's up and running.
br4dysays
will do, im using the FAQ guide for installing the headunit, well me and my bro gonna do it.
but i'll post some photos once its in.
should be sweet
i hate the S model cd player, im not sure how i put up with it for year already
danoops
Car: 2007 Nissan Versa 1.8SL Hatchback
You do not need a mounting kit. I made the mistake of buying it and I didn't use one part from the kit. I would suggest buying the wiring harness.
Also, don't buy from Crutchfield. They are way too expensive.
Also if you haven't seen it yet, check out the tutorial:
http://www.nicoclub.com/articles.php?id=227206
That helped me out a lot. Like the tutorial says, don't unplug the airbag light...there's one little screw that holds the light to the dash. The tutorial tells you how to cut and splice the existing wire, but I would suggest buying the harness.
Di Versa Fy
Car: 2008 Versa Hatch S - Dark Blue
Crutchfield is actually not that expensive. I checked all over for my stereo elsewhere and couldn't find a better deal when you total the order and include shipping. I also got a Free XM module for the home and car and a remote control. So for me the Crutch didn't cost too much.
Return to “Versa Technical Discussions”
