domdada wrote:Hey Doc,
I just bought the 8120 Navi Unit and was wondering if the wiring hook up is simular to that of the Avic-Z2s. Is there a write up how to hook up this unit? Or are the instructions on the Kenwood Manual pretty self explainatory? Thanks for the Help.
-Dom
Instructions are pretty much straightforward...
to watch videos and have access to Nav while driving, just ground the light green wire that is supposed to be attached to the parking brake.
for the reverse camera (if you hook one up), follow my Avic D3 instructions on accessing the correct wire
you don't need to tap into the vehicle speed sensor wire with the Kenwood units!
There's gonna be an extra light blue/red wire thDNX8120.. use that comes with your DNX-8120.....use that ONLY if you will be hooking up other powered devices to that via a relay... (For instance, the NISSAN baffle in my trunk opening is controlled by that, so I can tap the EXT SW button on my Kenwood, and control my cold cathodes from there) if you don't plan on doing anything fance like that, then don't worry about that!
I think that's it.. hit me up if you have any more questions!
