DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Fri Jun 20, 2003 6:18 am
Totally agree with fxjackso--new end link bushings will make a world of difference if they're 13 years old. But there's no labor overlap with the struts, other than getting the car on the lift, and actually they're fairly easy to DIY if you can safely get under the car with a few tools. The bushings are pretty cheap, maybe $3 each. You'll need 8 for the rear bar and 4 for the front. The front sway bar connecting links may need to be replaced, as the ball joints wear out and the seals tear. Those are pricier...maybe $30-45 each or thereabouts, I can't recall.
