Def »
https://forums.nicoclub.com/def-u8646.html
Tue May 04, 2004 7:39 am
If you have really short springs, then yes they can become loose at full droop. It is a common thing on most coilovers I've seen that are run really low(track use, not talking show kar here). Heck, it even happens on some "normal" springs for BMWs.
The only solutions are to get a tender spring that compresses under load and serves to keep a small amount of tension on the main spring, or to get a longer set of springs with the same springrate.
Just curious, but what length springs do you have?
