Does it sound like a tuning fork that adjusts tone depending on speed?eZg001 wrote:I just had the Nitto Invo's put on and am having a 'singing' noise from the front when freeway driving around 65-75mph. The discount tire rep described it as a 'harmonic resonance' noise. kinda sucks cause I set my cruise around 75 mph on my weekly 3.5 hour commute. not to mention all the $$$ I have dropped on the tires
Are your 555's doing this? I am thinking of pushing them to try replacing the front Invo's with 555's to see if solves the problem.....then trying to get them to swap the rears.
Thanks
I can only produce the noise in 6th gear between 70-80 mph with a peak around 75-77mph. I need to take it back to have the service manager ride along, but if you have any insight, I'd definitely appreciate it.SteveTheTech wrote:Is it is a wheels speed based harmonic noise or transmission related? Does anything change the pitch and frequency of the noise?
Yep.....sounds like the same exact thing. Mine starts a little earlier than yours, like around 65 mph. I just installed a 350Z tube and a K&N filter with stock intake and then put on these new tires. The old OEM tires were pretty noisy so I am not sure if the 'Tuning fork noise' was there or not. To be honest....I was trying to ignore the issue since I had such an aweful experience with a 350Z in 03Sentientbydesign wrote:
I've had that problem with my G since I go it. I've had the stock Potenzas, Michellin PS, and now Potenza RE-01Rs up front and all of them have made that noise.
Recently, I took apart my intake and it seems like the sound has a broader range now (70-80 versus 75-80). Not sure if the two are related.
The tech at infiniti tried to blame the noise on the tires, but having used 3 different fronts and 2 different rears, that doesn't work for me.
I've recently gotten an alignment too.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
