Question for all you spray painters
YuNg1's_240sx
Car: 1995 Black 240sx SE
Hey guys, I decided to tackle on spray painting. My spoiler was starting to show clear coat in the middle of it. So I decided to paint it. So I sanded it down with 600, but that seemed too high. So I used 320, and it worked a bit better, but still not effective enough. So, I bought 180 grit and it worked, but I think a bit too much! It started to cut into the plastic and left scratches. I thought the scratches would get filled in with the 3 layers of primer that i put down. It was rough in some spots so i sanded it a bit with 1000, i know it was too high but didn't have anymore 600. I then put down 1 light coat of color(black) and i 1 medium coat. The spots that were sort of sanded down are still a little rough and the color seems to be dull. Also it has a bit of white color to it. Is there something I can do to get rid of the white color and roughness on the spoiler, along with the scratches?
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
just sand it all down to bare plastic. primer, sand, primer, primer, paint, sand, paint, clear coat, clear coat..
the clear coat will take away from the dullness.
if there is serious wear on the spoiler, then use a filler to get it evened out.
YuNg1's_240sx
okay, well let me show you how far i am into this project.the white parts are rough and they look white. I want them smooth and to look black. what are the steps to get it like that?
1SickSilvia
Car: 1992 Nissan 240sx vert
sand the rough areas with 320 than 600 untill smooth, use bondo or filler if scratches are too deep or use spot putty, sand again with 600. Than prime it a few times, sand it again , 2 coats of color and I usually put 3 coats of clear coat on things I paint.
Dont rush it, let the coats dry properly before sanding or painting the next coat
YuNg1's_240sx
So youre saying to sand it to plastic again?
S13Joe
Car: 92 Coupe
Me and a buddy just sprayed parts of his rx-7 today. We did it very lazy but it came out good. We sanded with 150, wiped away then sprayed. I personally would have done it with 220 then wipe and clean then 320 to get out imperfections and make it nice then prime sand, prime sand, and all of that good stuff. We used rustoleum automotive primer and it came out great. I highly recommend that paint to anyone.
SEARCH and find answers, even google man. You flexing ****.
AZ89two4Tsx
Next time try wetsanding. Of course dry sanding is gonna leave scratches with 180 grit!!! That's WAY too rough. Unless you had deep scratches to begin with, all you would have probably needed was a good wetsand with 600. Even if it did have scratches, I wouldn't go over 220, and be easy on it. And then maybe hit it with 1000, again wetsand. You don't need to take off a layer of plastic, geez.
240sxFTW
Car: 89, 240sx coupe
and nobody cares about how much muscle you have.
AZ89two4Tsx
If only his brains were as big as his arms.........
S13Joe
Car: 92 Coupe
If only my pen15 was as big as my arm... god damn.
AZ89two4Tsx
It gets annoying after a while. Trust me.
S13Joe
Car: 92 Coupe
Exactly... My f***ing schiong is so small, I can only hope extenze works.
AZ89two4Tsx
Try sandpaper. 120 grit, dry.
S13Joe
Car: 92 Coupe
LOL please, after a while it gets old, I'm getting down with the 60 grit right now man. I have to say, no complaints so far.
AZ89two4Tsx
If hand sanding is getting a little to boring, try your luck with a belt sander.
Jadesr20det
Car: 1990 NISSAN 240SX
AZ89two4Tsx wrote:If hand sanding is getting a little to boring, try your luck with a belt sander.
Too much work just sandblast it
