Question for all 1999.5-2003 Pathfinder owners ---- Engine RPM
bullrid
Car: 01 Pathfinder LE
What are the RPMs on your pathfinder when running at 100kph or 60mph?
my 01 pathfinder is running about 2250rpm under no load at that speed, just wondering if this is totally normal or not.
Automatic or 5-speed?
Sounds about right, maybe a tiny bit low....
bullrid
it is an auto. i have driven V8s till now and they were all running under 2000 rpm, that is why it was wondering, to me, this seemed rather high.
Ah. Yeah, these "newfangled" import motors spin up a lot higher. It's not even close to working hard at that RPM.
max_stryker
Car: 1997 Nissan Pathfinder
at 70mph err 115kph its about 3000rpms with a 5 speed. out gearing is really nice though at 4.636 or others (4.325, 4.363, 4.9xx) jeeps and some other v8s have like 3.51s or 2.73s so its perfectly normal
bullrid
is it possible to change the gearing so that it revs lower, hopefully increasing fuel mileage.
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
2000 rpms at 60 mph
pathfinder_se_black
bullrid wrote:is it possible to change the gearing so that it revs lower, hopefully increasing fuel mileage.
4:10 gears but i havent realy looked into it.
max_stryker
good luck trying to find of 4.10 gears. NOT a clue in the world why youd want higher geears though...you can probably pick up a set of 4.363 drop ins...but its honestly not worth the cost and pita to install for like 1mpg better.
pathfinder_se_black
4:10 gears gives a better 0-60 time but it also increases fuel mileage(probably not to much), but i agree its not worth it.
fueler
Car: 2 Nissan's
2 BMW's
AZhitman wrote:Ah. Yeah, these "newfangled" import motors spin up a lot higher. It's not even close to working hard at that RPM.
Yeah my 99 Civic Si easily revved to 8200 fresh from the dealership!
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
2250 going 60 mph is normal if you have 4.636 gears. if you really want it to be at a lower rpm at that speed get 4.363s. i have a fairly new 3.3 with 4.3s and i can cruise at 60 mph at 2k rpms and 75 mph at 2400 rpms.
