Question for 4th gens with MEVI?
Y2KSESteve
I'm trying to find out who here on NICO is MEVI equipped. To those that have it equipped, what RPM switch are you using and when does yours open? I'm using the Summit switch, but it doesn't open until 5500 RPMs and thats a tad too late. How are you guys getting around that? TIA
maxhopper
Car: 02 Maxima SE 6spd
Hal should be back in town in the next few days, and IIRC he has the MEVI. Sorry I'm no help.
Y2KSESteve
Yea, Hal has the MEVI. I finally got it working this past weekend and I just want to work out all the bugs.. :cool:
turbo6
Car: '05 350Z Turbo, '98 SC300 9.3@156, '99 SC400, '02 Police Interceptor
Hi there,
I found 5200rpm was my best crossover, but I never tested it as much as I could have..
With the summit rpm switch, it was not as easy as just setting the rpm I wanted... and I was frustrated at first. Then I realized how easy it was.
Seems like everyones is calibrated to a different amount, but I found a very easy way to do it.
Get it somewhere near where you want (you are close enough at 5500) and then there is a screw on the inside for fine tuning. With the fine tune, I can adjust mine like 2000rpm haha. Just turn it left and right and watch where it changes. Luckily you have lights on the summit switch, so you can just sit in the car and rev it up/down and see where it is set to
Good luck - hope that helps
Y2KSESteve
hlh0501 wrote:Hi there,
Thanks! :thumbup
cullenj76
Car: 99 Q45t 04 SRT-4
MEVI might be my next mod, depending on a few things
Y2KSESteve
cullenj76 wrote:MEVI might be my next mod, depending on a few things
It's definitely worth it! I think my next mod needs to be the ECU. I still need to track down a 95-96 5 speed ECU and then the 6 week wait from JWT. :eek:
cullenj76
doesn't the lack of low-midrange tourque leave you wondering if you made the right decision, or does the power up top make up for it?
turbo6
cullen, I have a used-repairable one (I already have the part numbers and prices...err, did) you can buy for cheap :) if you want to do a little bolt turning on it to save some dollars.
cullenj76
i'll definetely call you about that. I'm tired of getting rolled up on the highway;)
phenryiv1
Car: 2003 Sentra SE-R SpecV
Would the JWT do any good if I am still NA?
Y2KSESteve
cullenj76 wrote:doesn't the lack of low-midrange tourque leave you wondering if you made the right decision, or does the power up top make up for it?
IMO the top end power is worth it. I really did not feel a big loss in midrange power with the MEVI.
cullenj76
phenryiv1 wrote:Would the JWT do any good if I am still NA?
Yes, with or without the MEVI, the JWT ECU is a great mod for NA applications.
Steve: Thanks for the info.
