Question Drain Flange
DammitBobby
Car: S13 91 KA24DET
I tried making a drain flange gasket out of gasket material but it end up leaking. I have decided to buy from Tunertoys.com because they sell a kit that has the -10an male made into the flange. My problem with buying from Tunertoys.com they do not list just the gaskets so I can order extra gaskets with the flange kit.
Other web sites only list gasket that says it will work with t3 or t3/t4. Tunertoys.com lists flanges in mm. I measured mine and it is 44mm from flange bolt center to center. Are all T3 and T3/T4 44mm flanges? If so where is everybody buying gaskets? I read on another web site JGStools.com recommends using Rutland Hi-Temp Stove Gasket Cement. Has anybody used this?
steve s14
is this the one you're looking for?
teddy
Car: Saab Turbo and MR2
I bought my t3 drain flange gasket from ATP Turbo for $1.65. If you're looking for an actual drain, I also bought a drain flange with a 5.8" ID pipe attached to it on ebay for like $12. It looks similar to the stock t25/t28 drain flanges.
DammitBobby
Car: S13 91 KA24DET
Yep that is what I am looking for. I emailed tunertoys.com and they sold me 2 extra gaskets for 3 bucks each.
http://tunertoys.zoovy.com/product/ODFAN44K
