zarar »
https://forums.nicoclub.com/zarar-u151366.html
Tue Mar 29, 2011 12:46 pm
I assumed bluetooth streaming is hardware based, could be wrong. The bluetooth in the car (Non Nav) is just for phone calls, the bluetooth module itself would have to be A2DP cable in order for it to work. Maybe its possible for a software update or a possible hardware retrofit maybe another solution. Either way I think the dealer can only do it for you, if they are even willing to and at what cost (I say this because I can't imagine anyone have access to their software but themselves). If a dealer can charge $100's for a simple GPS map update, imagine they would charge for something like that. Right now the Radios with Navigation have the ability to do so (BT Streaming). Think of it as an operating system (So basically Non Nav is Windows 7 Basic, the one with Navigation is Windows 7 Ultimate), the current OS your running doesn't have that ability (Non Nav), so if they were to "update", it they would give you the software that has Navigation capabilities (Nav Menu and all), but then you would have a lot of features missing because of lack of hardware (Nav Unit, built in HDD, etc.). So then you would basically have a stripped down Nav software version, just to include BT Streaming which for them wouldn't be practical and cost effective, its why they bundle everything in a package (You'll notice you do NEED the updated Software because it has the option to Turn ON and OFF BT Streaming). A simple software update wouldn't really work if you think about it. Unless they decided to go out of their way and redesign their system software to not include Nav and other features, to just add BT Streaming capability (Same as if you were to buy a regular bluetooth headset and use it for phone calls but then one day decide to use as a mp3 headset. It just wouldn't work, thats why you'll notice they offer More Expensive headsets that are Bluetooth + A2DP Capable. Its why I assume it's hardware based). But that's just my thoughts if I were to get technical with it, hopefully what I said made some sense (have a fever and totally out of it lol).
... Just an assumption, always can ask your dealer and see what they say. Good luck, if it happens to workout, I'll be right behind you on the software upgrade since I don't have BT Streaming either.
