Question before installing 86-91 rx-7 injectors
xKnownShadowX
Car: 94 Q45a
I was wondering do I need a tune if I toss on some 86-91 RX7 (195500-1350) injectors on a sohc NA?
Thanks in advance.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
xKnownShadowX wrote:I was wondering do I need a tune if I toss on some 86-91 RX7 (195500-1350) injectors on a sohc NA?
Thanks in advance.
there is a formula for choosing injectors....ie..flow rate per cylinder to make X horsepower...its somewhere in this forum...this will guide you in choosing injectors for the tune or build you may be planning..good luck
the search function is in the upper rite corner under the google banner.
xKnownShadowX
Car: 94 Q45a
I just wanna know the odds and benefits or doing this with out a tune plan.
liquid_cool
xKnownShadowX wrote:I just wanna know the odds and benefits or doing this with out a tune plan.
well..word of advice...if you dont have a plan for a build or a ecu tune..or an upgrade...dont waste your money...
xKnownShadowX
Car: 94 Q45a
I have a turbo kit that is sitting but my engine I think is not worth building into a turbo.I got two pairs of injectors, RC racing ones for the turbo setup and rx7 spares.I'm not wasting money I just got them sitting and I think my injectors need replacing, if not I just think I might as well replace anyways.
Let me know thanks.
My main plan was turbo cause I got most things I need but since I just went NA now might as well do something with the injectors.
r3v_v3ng3
Car: 91 fastback ka-t
nothing probably blow op your engine. rich on idle and lean on boost if you decided to turbo it without tune. figure out the cc on the rx7 (thinking 440) and see if its low or high impedence. then get someone to chip the ecu for your turbo set up
