Coolwhip »
https://forums.nicoclub.com/coolwhip-u13264.html
Wed Sep 19, 2007 4:32 pm
if the transmission mount looks stock, see if you have a stock driveshaft as well, or if the transmission is a skinny like a KA transmission. If so, you might have a RB20 transmission in which you might be able to do a straight foward clutch install. If you have the larger RB25 transmission, you might run into what I heard, removing the whole damn engine and transmission to do the job.
