SlideRite44 »
https://forums.nicoclub.com/sliderite44-u240347.html
Tue Dec 16, 2014 2:25 pm
hmm, what tension rods did you get? the Nismo rods use the OEM 17mm but there is a possibility if you have a pillow ball rod end, the bolt may be a bit stiff to get in there. Is it WAY too big, or just a tight fit? Alot of build up will occur on those bolts so if you have a wire wheel handy or some scotch brite, just buff the bolt up and clean it, run some grease and get it in there. I upgraded my entire rear suspension to pillow ball ends and some of my crappy old bolts did not want to slide in all that well. I just ran the wire wheel over them and used some gear oil and that did it.
