Question about z32 brake sizes
vwluv10338
I did a search and cant find exactly what I want. What exactly is the difference between the 300zx na and tt brakes. Is the 30mm vs 26mm just the width or the rotor and what are the diameters of the two rotors? The the rotors the same size but just one is thicker than the other? Also, just by looking at the calipers is there a way to determine if it is iron or aluminium?
Eric
vwluv10338
I also found this on ebay for rotors:
This set of FRONT & REAR rotors will fit :Nissan 300ZX na from 08/90 to 96
Nissan 300ZX turbo 07/89 to 96
If your ZX is a non turbo and have a production date between 02/89 to 07/90 please ADD $35 because it use different front rotors.
Are the 26mm rotors only on an 89-90 non-turbo?
Eric
Dori Dori
Car: Cars of course
All your questions answered here grasshopper...http://importnut.net/300zxbrakeswap.htm
vwluv10338
Awsome, everything I needed was in there. I am asking because after I maxed my stock brakes and they faded I decided it was time for brakes before more speed. I have found a good deal on the 26mm, probably around $30-40 for front calipers. Should I just go with them and not worry about the 30mm being better?
Eric
Exar-Kun
Car: 2005 350Z
if you're anal about having a 4mm wider rotor...-chet
vwluv10338
Just got 26mm front calipers off ebay for $36. Screw the 4mm, I'm happy.
Eric
