question about wiring RB25
GIJOE69
Car: Going Side Ways!
hello I have read the articles and write ups especially downloaded the files from racebread.com on Rb25 S2 S14 write up i just had a question about reading the file if it says " Original Pin Location" would that be from the RB wiring harness and also if it says "Move to Pin #" would I be cuting the wire off the KA ecu and splice it into the RB harness?
300Plus
Car: 1995 S14 w/ Rb25det Series II
The guide was written on re pinning the RB M63 plug. So no you don't cut and solder wires, just pull the wires out of the plug (carefully) and relocate them to where the guide says, on the same plug. make sure you understand which side the plug is being read from. compare to KA plug pinout and double check w/ multimeter. The guide has been proven correct but is intended to help not guide completely, it is still easy to get confused and mess up. Post your results
GIJOE69
thanks! for the info about re-pinning!
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Yes, what 300Plus said.
I cut and soldered the connections because I didn't want to bend/f@ck up the pins by trying to push them out.
