question about wheel size--?
POOPmouth
Car: The Devils pimp ride
r32 brakes - 16X7 +28 OFFSET OLD SCHOOL ENKEI MESH *BBS RS STYLE
will they clear - r32 brakes
if not what is the size i should go with - ?thanks
rb20det_pwr
Car: skyline hcr32
On the front or rear? Assuming its for the front, looking at that spoke design, im gona have to say no. Probably need at least a 20mm spacer...but dont quote me on that
POOPmouth
what would you sugust ?
rb20det_pwr
Car: skyline hcr32
Clearing the brakes depends on spoke design, not offset..So if you REALLY like those rims, just run a bolt on spacer. But with a bad offset, when you see them on your car, your not going to (probably) like the rims anymore.
But if they are just sitting at your house with good tires and they fit, may as well run them. But the *perfect* set of rims takes a lot of consideration of what YOU want.
POOPmouth
true - so true
crzycav86
Car: 93 Nissan 240SX KAT
rb20det_pwr wrote:Clearing the brakes depends on spoke design, not offset..So if you REALLY like those rims, just run a bolt on spacer. But with a bad offset, when you see them on your car, your not going to (probably) like the rims anymore.
this is true.
typically mesh rims do not clear big brakes.. so i'm going to say no.
