You should be a hi press fuel pump even if you're running the stock boost.killablue240 wrote:boost controller fuel pumpfmic
I don't have one. I seem to be getting by fine, but can you explain why I should invest in the 255lph over the stock? Am I causing damage, or .. lowering efficiency in any way? My SR is running stock everything as well.otterman wrote:
