question about turbo
Alastaplat
Car: 1989 240sx
I see all these turbos all over the place but a majority of them are for the SR20I have the stock KA24de and I just wanted to know if I'm able to use one that's labeled for the SR in conjunction with my motor and how I would go about doing that if it is possible....
anything would help really... thanks
FattyInA240
Car: 90' 240sx fastback sr20det
to be simple .... no, u cant use a sr20det turbo the flange size is different u need to do some research before u just start bolting on turbos u will have to replace ur header and exhaust system there are a few websites that are ka24de specific. just google that ****,.......ka24det......good luck with that
(too*for*tee)
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Simple. Buy a Megan or SSAC exhaust manifold. You will be able to use the downpipe, hell, everything from the turbo side of an SR on your KA. Barring internals and sensors, there are few engine specific parts between the SR and KA.
480sx
Car: 1996 Pearl White 240sx
Actually, you can use the turbo in a Ka. People do it all the time.... You would have to get an aftermarket T2 flanged turbo manifold. You can find the cheap ones on ebay for about 125 bucks shipped. But remember you get what you pay for.
However, a SR turbo is really small. The ka24 is a big 4 cyl, and is much better off with a t3 sized turbo. To be more specific, the best turbo for our engine is a t3/t4 hybrid, 50 trim, .63 ar.
adrianfromthecastle
Car: 1992 Nissan 240sx
depending on what turbo you choose to get, just make sure the manifold's flange will take it (i.e. t2, t3). you can use an sr20 turbo as long as you have a t2 flange
Alastaplat
Car: 1989 240sx
if I plan to bore my engine, should I get a bigger turbo?
180fan
Car: 89 fastback
boring a ka with a turbo? how far do you plan on boring the thing...my magic 8ball is saying "outlook not too good" without sleeving that is...
adrianfromthecastle
I was under the impression boring is more for n/a applications... with those cylinder walls that much thinner... a tubos just gonna make it a ticking time bomb
Alastaplat
Car: 1989 240sx
what is sleeving?
Slipstream
Car: '94 Sonoma, '90 300zx n/a
Sleeving is basically cutting out the current cylinder walls and replacing them with stronger thicker walls. Darton makes some, just not sure for the KA. Pick up the ne DSport magazine, they have an article on sleeving.
