evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Sep 02, 2006 6:24 pm
yes you can turbo using only the turbo exhaust manifold, turbo (has an internal wastegate), downpipe, oil lines, Oil "T", fuel injectors and pipiing (stock "J" pipe or otherwise), depending on what your engine set up is you might be limited on boost, unless you have a turbo block your really gonna want to keep it low boost, this is the absolute minimal to get your L6 turbo'dto do it right you want the complete turbo donor: harness, injectors, fuel pump, ECU, engine along with the other items already listedone great reason I have found for the complete swap is that it really helps with the learning curvethe intercooler isn't required untill your running more than 10psi on a low compression motor, everything else will get you in the 275 whp range, at which point the stock managment system Injectors and turbo are all rpetty well maxed out, the stock block (in good shape) can make right about 400 whp before the pistons give up the ghostand if your gonna gamble the boost on a stock motor do not skimp on the boost gauge or the boost controller!boost is addictive and it's easy to get greedy
