Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Wed Dec 06, 2006 6:19 am
Both, the turbo is still spinning. While it may screw with people, it's just the way it is. While it may not be making boost, it will be moving air, which would otherwise hit a closed throttle plate. And eventually make positive pressure, this is how Roots blowers make boost (by backing air up in the intake tract). This is assuming it didn't surge the compressor first, or experience blowby on the wheel.
You can help remedy it a little by tightening your valve down, but this may cause you surge, so be careful.
Also, it happens because it has vaccuum from the mani on one side, and positive (or at least atmospheric) pressure on the other side, which is enough of a pressure differential to cause the valve to unseat and overcome spring pressure.
This is why I still contend that a cheap BOV would work as well as any other, since the only important parts would be the diaphragm and spring. What can they cost to make?
Anyway, I just have the DSM 1G BOV.
