ppazz1101 wrote:Very valid points. While the car isn't meant for the "tuner" market, it shares at least a motor with a car that is (350Z). Hence why I ask if anyone knows which ECU is used. The Cobalt SS (non supercharged, which is what mine is) benefited from the aftermarket for the Corvette and GTO, both of which share the same ECU, but run a different OS.
As far as warranty goes, it's not much of an issue with a full tuning solution. You're not replacing the ECU, just retuning it. If you put a "canned tune" on the ECU, it is detectable by the dealer. With a tuning solution, you can always load a stock tune back on the ECU. Another benefit of having the full solution. Although, in my personal experience, the dealer shops rarely check the ECU for modification.
there is a ECU tunning chip thingy, it's only for the 6MT and supposedly it removes rev limiter and speed governor and does other neat tricks:
FEATURES:
REV limiter modificationWe found that with the ECU upgrade, more power can be gained with a higher rev limiter. A 7100 RPM (stock 6600 RPM) rev limit is set to take advantage of top end horsepower, while still providing a safe protection for the motor.
Speed Limiter RemovalThe stock speed limiter of 236 km/h (148 mph) has been removed.
Ignition Timing Map AdjustedThere wasn’t much room for improvement at the bottom end since the ECU retards a lot of timing by using a feed back system in stock trim. So, we have added more timing at the mid range - high end to take additional advantage of higher-octane gasoline. This aids in improving torque from 3000 rpm and up.
Fuel Map AdjustedStock fuel was set to detune the top end horsepower. We discovered that the car runs extremely rich after 5000 rpm. Air to Fuel ratio (A/F) of 10.8 was found right before the stock rev limiter kicks in. Cleary, Nissan was trying to detune the power output at higher rpm to discourage the driver from hitting the rev limiter. For the performance enthusiasts, however, this is unsatisfactory, so we set the A/F to 12.5 all the way to redline to provide adequate power gain while still maintaining a safe margin.
Drive By Wire AdjustmentThrought our testing we found, the drive by wire system was program to never fully open (throttle flap) when you smash the accelerator pedal. In fact, it actually closes the closer you get to the rev limiter, by as much as 20%. This restricts air into the motor and causes HP and Torque numbers to go down. We have remapped this setup so when you go wide open throttle, the throttle flap fully opens and STAYS OPEN, increasing HP and Torque.
there's the thread :
zer...93087
