Big Perm »
https://forums.nicoclub.com/big-perm-u7907.html
Fri Mar 12, 2004 8:06 pm
I was told that you want it to be around .5 my S1`4 SR manual says that it should be adjusted like this
1. Install throttle position sensor in throttle body. Do not tighten bolts, leave bolts loose.2. Connect harness for sensor3. Start engine and let it warm up sufficiently4. Adjust by rotating TPS body so that output voltage is .35 to .65v 6. Tighten bolts7. Disconnect TPS sensor harness for a few seconds then reconnect it
8. Go spin Tires!!!
Hope this helps
