My momma said Nissans are for the debil!NFSP G35 wrote:You probably live just down the road from the waterboy.
How exactly does ownership of two Redneck Ferraris make you an expert in sports cars?NFSP G35 wrote:A 1994 Trans-Am, a 2000 Trans-Am
So tell me "sunshine", those mullet-mobiles have the T-tops? Did you rock out to Skynyrd while cruising around in your wife-beater, smokin' Malboro Reds and speeding to your job to man the controls of the Tilt-a-whirl at the local carnival fair?NFSP G35 wrote:that's the sunshine state
In the same way as ownership of a wrong-wheel-drive Scion and a Mazda with no motor make NFSP 350 one!NFSP_MX5 wrote:How exactly does ownership of two Redneck Ferraris make you an expert in sports cars?
First of all, only one of them did. Second, what if I did? At least I don't drive a car that generates remarks about 'coming out' Mr. MX5And one more thing... It was the GravitronNFSP_MX5 wrote:So tell me "sunshine", those mullet-mobiles have the T-tops? Did you rock out to Skynyrd while cruising around in your wife-beater, smokin' Malboro Reds and speeding to your job to man the controls of the Tilt-a-whirl at the local carnival fair?
Glad to find some one using a similar setup. One of the main reasons for my asking was because I know shocks can wear out faster if they're run to close to their limits, like say if you run non-sport sedan shocks with 350 springs. But if you're running Tein springs for a Z on a G Coupe and the D-Specs for the G are doing fine, then they shouldn't have any problem at all on a Sedan with stock Z springs.BTW, how long have you been running that setup, and how do you like the D-Specs?AZhitman wrote:Use the ones designed for the G. I have the same setup on my 03 G Coupe, with the 350Z Tein springs. Works great.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
