What sort of garage will drill 4 holes on a 5 bolt rim?SuperTurbo wrote:Well... which yr of Corolla??
If it's a 4 bolt Corolla, you can have a try.
If you got a 5 bolr Corolla, you got 2 solution1. see which garage will help you to dril 4 holes on each rims, but it will be quite expensive
2. Like what Knightro2 said, a set of steel rims
I know it sounds weird, but suprise enough, some garages will do those kind of work...Andrews Chalmers wrote:
