Very close, but not quite exact. Between the metal t piece and the intake connection after the afm the above happens, meaning the line is basically a waste line, where the bled off pressure from boost solenoid returns to the intake system. The line running behind the rear of the head is also a waste line returning bled pressure from the secondary intake butterfly control solenoid back into the intake system. It basically allows everything to be a closed metered system.dattodude wrote:Here comes the answer :-)
It's the vaccuum line that the ECU controlled boost solenoid bleeds pressure off from the vaccum line from between the turbo and the wastegate actuator. There is a metal t-piece it connects to above the turbo.
Chris
