Question about the timing belt/chain
Notorious-Sky
Car: 1996 R33 Skyline GTST
Ok as dumb as this sounds - here goes.
My R33 GTS25m RB25 has 106000km on the odometer. I know in most cars the timing belt/chain is recommended to be changed at about 65-70kmiles. Is this the case with the RB25 and if so can anyone tell me if there are any specific pitfalls or quirks to doing this procedure?
Thanks for your help
PeaceTodster
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
Iy is recomminded when you do the swap that you chang the belt. 1.UN BOLT CRANK ANGLE SENSOR2 UN BOLT UPPER TIMING BELT COVER3 UN BOLT THE WATER PUMP PULLY4 UN BOLT LOWER COVER 5 LOOSEN THE BELTS P.S. AND ALT6 TAKE OFF THE HARMONIC BALLICING PULLY7 UN BOLT THE TIMING BELT TENSIONER ON THE LEFT SIDE 8 CHANGE BELT 9 BEER BREAK 10 PUT BACK TOGETHER I am not responiable for anything you mess up during this
Notorious-Sky
Thanks for your assistance. I am not real mechanically inclined but i made a print of this so I can get with the guy that helps me out with the car. One other stupid question. Any idea what timing belt will fit the car ? Is it specific on the the RB25 ?
Thanks
PeaceTodster
sean8564
1993 Nissan Silvia
I bought mine from heavy throttle for 59 plus shipping the belt they sent was from pit work so it is quality for the money 1866-4sr-swap call them and see about another one
Notorious-Sky
once again thanks for you help. It is really nice to be able to talk to people that know something about the car and engine rather than just "shots in the dark".
Just one more question, is heavy throttle on line, are they a NICO sponsor ?
Thanks again for your help
PeaceTodster
sean8564
1993 Nissan Silvia
Yep they are a NICO sponser http://www.heavythrottle.com
wawazat8402
Car: 89 Sil80- RB25DET
might as well do the waterpump while youre there.
sean8564
1993 Nissan Silvia
this is true for that you will need to un bolt your alternation cause 2 of the water pump bolt are on the alterator also the RB25 stock oil pump is crap you should look into getting and N1 pump
Notorious-Sky
thanks guys for all your advice - i found the belt on their website and will check on the oil pump and water pump tomorrow during business hours.
Thanks again !
PeaceTodster
sean8564
1993 Nissan Silvia
They don't sell ether I can source you a N-1 water pump and oil pump if you want
Notorious-Sky
that would be great Sean - I really appreciate the help !
PeaceTodster
sean8564
1993 Nissan Silvia
i called nismoN1 water pump is 154.50 oil pump is 225 the number is 1 (310) 538-2610 then #3
74260zt
Car: rb26powered early 74 260z car
Check this info out, it should help you out..... http://www.skylinesaustralia.c...73824
Notorious-Sky
Thanks for the link - very informative dont know if I am ready to try this myself yet although it looks as if i could accomplish it. Very very good information - THANKS !
PeaceTodster
Notorious-Sky
Thanks Sean - I will call Monday or Tuesday to get ordered! Looks like this project is getting off the ground !
PeaceTodster
sean8564
1993 Nissan Silvia
just rember if you are in Ga I want to ride in the R33
Notorious-Sky
Nope im in TX but ur welcome to ryde anytime you can make it down !
PeaceTodster
sean8564
1993 Nissan Silvia
thats cool i am taking the s-13 on a road trip to CAL
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
Where in Texas? Austin area by any chance?
Notorious-Sky
West Texas - near El Paso
