Question about the spark plugs and gap (Y33)
Mopar
Car: Infiniti Q45 1998
Since I got a great deal on the coils for the Q, I am going to change the plugs with them. What kind of plugs do you recommend? I heard bosch ones are not good?
Also what is the gap supposed to be in the plugs?
1990QOwner
Car: 1990 Q45
If I was you I would get OEM from Joe.
I believe the gap is the space at the end of the spark plug and the little wire type thing that bends over the end....Sorry, I dont really know how to explain it but I guess that is the best I can do. I'm sure the Q experts know the right term for it.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
get the OEM NGK plugs from Joe and DO NOT adjust the gap.
Put them in the car and be happy. OEM plugs do not need gap adjustments, and non OEM plugs can destroy your motor.
Mopar
Thanks guys, I meant the gap how much is it supposed to be. NGK it is
elwesso
2007 BMW M Coupe
There is no gap to worry about. Factory NGK it is..... take out of box, insert in car, press gas pedal fully.
Mopar
haha thnx Wes, Any tips on changing the injectors and coils? what should i look out for? what should I clean?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
TCS and throttle body plates. EGR and Iac valves. Have the new gaskets.
RTFSM
elwesso
2007 BMW M Coupe
Mopar wrote:haha thnx Wes, Any tips on changing the injectors and coils? what should i look out for? what should I clean?
Y33 i cant help you but its not nearly as bad as a G50... why would you change injectors on a Y33 anyway? Coils should be slightly easier due to there being no coil pack cover and overall easier to get to.
Mopar
Because I have that hesitation and "jiggling" problem if I hit the gas like 20-60% in, I either have to floor it or do under 20 to not feel it. Well I am going to change the coils first see if it helps then do the injectors.
tmorgan4
Car: 2000 Nissan Pathfinder
Always checking the gap even with brand new plugs isn't a bad idea. Shipping is rough on things. Anyone happen to know specs?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
tmorgan4 wrote:Always checking the gap even with brand new plugs isn't a bad idea. Shipping is rough on things. Anyone happen to know specs?
Not if they are shipped in OEM containers.
11 refers to 1.1mm. You may will alter the paralellism of the gap if you do not have a professional gapper.
elwesso
2007 BMW M Coupe
maxnix wrote:Not if they are shipped in OEM containers.
not doubting but what is your source on this information.
qship96
Car: 1996 Infiniti Q45
Agree,check the gap with a round-wire gauge-my recent factory plugs were either spot on,or close when I tested them before Byron installed them last week.
By the way,the old plugs with 132,000+/- miles on them came out easily and all looked fine-no oil or carbon fouling,uniform light grey insulators,no erosion to electrodes-would have made it to 150,000+ on them,but valve cover gaskets were slightly weeping only when cold,and have been for the last 3-4 years-figured I would get em done along with plenum while I was in Atlanta
