nissanfreak12 wrote:As far as I know, that coming from the temp sensor to the ECU, not the one to the dash. You should burn the ECU by being swapped, the worse it will do is throw it in a loop, ie like the sensor is bad. Swap the wires and hook it back up, see what happens. All the sensor is a thermal resistor.
How do you know it is running rich?
Guess I can swap the wires then since there is little risk of further damage. However if I am getting temp readings from my datascan software & its getting it via the temp sensor to the ECU, then it seems that it is in fact already connected correctly. I was hoping for a quick fix but at least I can now eliminate the sensor as the problem. Thanks for the feedback "nissanfreak12". The car is running SO rich that it is undrivable. The last 5 times that I have test driven it in order to see if my adjustments have made any difference, It has backfired loudly, won't accelarate smoothly & left me stranded a couple of times. I can smell the fuel from inside the cockpit. I've had the detonation sensor code 34 for a long time but Its never been undrivable like this so I doubt that being in "Safe Mode" is causing this problem. My theory is not that the car is delivering too much fuel, but rather that since I have 2 dead cylinders, there is no spark in those cylinders but the injectors are still dumping fuel into them thus causing this rich condition.
Its not the coilpacks & I have cleaned up the PTU connections & zip tied the connections together since they were loose. The injectors tick as they should & I scraped the pins on the CAS. All the grounding points are tightly screwed down. I wanted to check the PTU itself with a multimeter but I can't get the connectors off & I'm scared of busting them cause then I'll have yet another variable to worry about. I love this car but its kicking my arse.
